Description
A special wide frame machine for testing foam and seating. Used extensively in the automotive seat and furniture industry. The machine has special internal software for conducting multiple stage cyclic and indentation hardness testing.
 Force Measurements
Extension Measurements
Speed Control
Load Frame
Software
